Repair guides and support for desktop PCs manufactured by Lenovo.
Power supply replacement question
I have a pc that needs a new power supply. It's a factory Lenovo, nothing fancy... I also have several old computers laying around. I want to see if I can just use the power supply from one of those but I'd like to be sure about compatibility before I start experimenting.
The first pic is the one I want to replace
Is this a viable replacement ?
Thanks for your time!
Это хороший вопрос?
Счет 0
1 Комментарий
A big thanks to everyone who responded. My machine is back up and running like a champ!
из
Добавить комментарий
2 Ответов
Выбранное решение
Plug things in properly and go.the one you want to install meets the needs of the pc.if you start adding things that take more juice you will need a bigger one but they are everywhere,like ebay
Был ли этот ответ полезен?
Счет 0
If the form factor is the same and it has the same or more output power than the broken one ( it does ), and it has all of the correct connections there is no reason why it wouldn't work.
Check the molex connectors, does it have enough? Does the molex connector that connects to the board match? It most likely does.
Счет 0
Добавьте свой ответ
Rep Tilicus буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 11
За всё время: 225
