Fujifilm FinePix 16.4 megapixel HD waterproof digital camera has the ability to capture up to 10.10fps. Released on 2015.
Вопросов 10 Показать все
Camera only takes blank/black photos? Nothing appears to block lens.
My Fuji FinePix XP85 works fine except for taking blank/black photos/video. There doesn't appear to be anything blocking the lens. I've taken the battery out to reset things and put it back in. That made no difference. What would cause this and how do I fix?
Это хороший вопрос?
Оценка 1
1 Комментарий
I have the same dilemma as @brenlm- except my screen is fine to the eye but when you go to take a picture the screen becomes frozen and unresponsive. Its been like this for a long time I'm so clueless as what to do with it?
из
Добавить комментарий
Ответов (2)
Выбранное решение
Hi @brenlm ,
Can you see an image of the photo you want to take in the camera's LCD monitor screen?
If not, can you view the menu screens in the monitor OK?
If you cannot see the image but can see the menu screens then the most likely problem is a faulty CMOS image sensor in the camera.
Try taking a photo (I realize that you cannot 'see' what you are taking) and downloading it to a computer to check what the photo is like.
If the downloaded photo is a black or blank image then you have a faulty CMOS sensor
Unfortunately I've been unable to locate a CMOS sensor replacement part for your model camera. You may have better luck.
If you cannot see the menu screens either in the monitor, try taking a photo (I realize that you cannot 'see' what you are taking) and downloading it to a computer to check what the photo is like.
If the downloaded photo is OK then you have a faulty LCD monitor.
If the downloaded photo is just a black or blank image then you have a faulty CMOS sensor and a faulty LCD monitor or perhaps a faulty motherboard which is affecting both.
Has the camera been dropped or gotten wet at all?
Был ли этот ответ полезен?
Оценка 2
Try turning sd card around?
Оценка 0
Добавьте свой ответ
brenlm будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 6
За последние 30 дней: 32
За всё время: 5,120
