The Singer EZ-Stitch Chainstitch Sewing Machine is meant to help beginners create their own fun and creative projects. It can be used to assemble crafts, clothing, pillows, accessories, and more.
7вопросов Показать все
Thread gets stuck in machine
My singer machine has thread that gets tangled in the machine. I have gotten it out following the book, but it happens again every time I try to sew. I can’t use it at all. I bought it at least 10 years ago & didn’t use it for the first couple years, then we moved. I tried using it & had that problem immediately. I asked my sewing teacher & she told me it would cost more than the machine is worth to fix it. I can’t afford to buy a new one. I picked it up for like $115 at Target. Not the highest model. I also followed instructions for threading.
I have a different model than chosen. It’s a much better machine than this.
Это хороший вопрос?
Оценка 0
3 Комментариев
Its not the machine pictured. I have a full size machine.
из
@magecat any idea what model your machine is?
из
It’s a much better machine than the one pictured. It has several stitches. There is a bobbin beneath the plate, none on top.
из
Добавить комментарий
1 ответ
Выбранное решение
Is yours a chain stitch machine like the one pictured, or does it have a bobbin beneath the plate as well as a bobbin in the top?
I wrote up all I know about sewing machines at https://wiki.restarters.net/Sewing_machi... - perhaps the tension is wrong, or the needle is bent, or the timing is out.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
ladycerridwyn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 1,244
