Швейная машина Singer EZ-Stitch Chainstitch предназначена для того, чтобы помочь начинающим создавать собственные интересные и творческие проекты. Её можно использовать для изготовления поделок, одежды, подушек, аксессуаров и многого другого.
Thread gets stuck in machine
My singer machine has thread that gets tangled in the machine. I have gotten it out following the book, but it happens again every time I try to sew. I can’t use it at all. I bought it at least 10 years ago & didn’t use it for the first couple years, then we moved. I tried using it & had that problem immediately. I asked my sewing teacher & she told me it would cost more than the machine is worth to fix it. I can’t afford to buy a new one. I picked it up for like $115 at Target. Not the highest model. I also followed instructions for threading.
I have a different model than chosen. It’s a much better machine than this.
Это хороший вопрос?
Счет 0
3 Комментариев
Its not the machine pictured. I have a full size machine.
из Поделиться
@magecat any idea what model your machine is?
из Поделиться
It’s a much better machine than the one pictured. It has several stitches. There is a bobbin beneath the plate, none on top.
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Is yours a chain stitch machine like the one pictured, or does it have a bobbin beneath the plate as well as a bobbin in the top?
I wrote up all I know about sewing machines at https://wiki.restarters.net/Sewing_machi... - perhaps the tension is wrong, or the needle is bent, or the timing is out.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
ladycerridwyn буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За все время: 1,769
