Problem Solved:
I tried to clean up the drive after uninstalling some vampire programs in the background didn't help. Didn't make a dent (battery life still ~2 hours), so I backed up my drive with Time Machine, then erased it, and reinstalled the OS which ended up being Mountain Lion (#tbt). I had some issues because I had two factor verification on and Mountain Lion could not handle it, so I ended up using my phone to deactivate that and then being able to update to High Sierra. Once that was complete, I had some issues with the local keychain dialogue box coming up and requiring my password but not accepting it. I found a solution that worked for me Here
The directions I followed:
"Open Finder. Choose Go -> Utilities. Locate Terminal and Open It. In Terminal, type the following command:
cd ~/Library/Keychains and Press ENTER
then type ls and press ENTER to list the contents of the Keychains directory. You will see a long string with random numbers.
[In the little video loop he then types ls -al (but forgets in the text to mention this, which is a critical step turns out lol)]
Type rm -rf then type the first three letters or numbers in the long string as you see and press the TAB key to get the full name of the folder. Press ENTER. Repeat the steps, if there are more then one folders of this type. "
Battery life is estimated to be about 5-6 hours now. I haven't restored my back up and I may not, might just get things off my external or iCloud as needed.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
0
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
3 Комментариев
Can you download Coconutbattery with the MagSafe charger connected take a screenshot of the main window and paste it here for us to see.
Adding images to an existing question
из Dan
Done! Thank you for taking a look at the issue!
из Carolyn Oppenheimer
I added a screenshot from another app (iStat Menus) showing the battery health at 88% and that it's going to take 1 hour to charge from 85% to full charge.
