Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
3D Touch on replacement screen
Hello Ifixit! My question is that if your replacement screens have the same 3D Touch feature on them. I always use that feature on my phone and well I think it’s very useful. Another question by the way, also related to the screen, is that what do you think...should I replace my screen because I have like white splotches on it. So like when I open an app like YouTube with its white background I can see them much more than on a dark background. One more thing is that well I don’t think it’s water damage because in Apple website they say it’s more of some foreign thing intruding the LCD. Also what do you think is causing this? Should I replace?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi, the white spots indicate that the backlight sheets are water damaged. Seems like you have Got Some waterdamage.
I suggest you clean your phone first by exampele 99.9 alcohol. If your experienced you can clean the sheets behind the lcd to this wil make the spots Go away (water has come between the laters of the sheets).
If you want to Replace with a good 3D function get an original screen with a trusted supplier.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Well I don’t think it’s water damage because I went Apple website and they described water damage as dark but the white splotches as something intruding the layers of the screen. I just want to know but I’ll soon know
из
Добавьте свой ответ
Uriel Trejo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 150
