MacBook Air stuck at welcome screen
My new MacBook Air is stuck at the welcome screen. What now?
Это хороший вопрос?
Это хороший вопрос?
I would try booting in Safe Mode (hold shift while booting) and see if you can get in. If this works, there is something that is launching that is stopping the system from booting. Therefore I would go into System Prefrences > Users and Groups > Your login > Login items and then disabling anything you don't recognise.
If this doesn't work, try booting to recovery mode (cmnd + R). This should allow you to reinstall the OS. I would try not wiping the drive first as reinstalling can keep your current Apps and data. This could solve the problem. If you can't boot to this recovery, you can try internet recovery which is basically the same thing but it loads everything over the internet. To do this, hold (cmnd+optn+R) when booting.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 818
Do you have access to a second Mac that you can connect your MacBook Air to using a Thunderbolt cable? Or have a blank USB thumb drive that you can setup as a bootable drive?
из Dan
