Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577вопросов Показать все
Turn iPad off when testing without touchscreen
Hi,
Just replaced de iPad battery, and placed back the logic board and LCD. After that I wanted to test the LCD, and this worked out fine. But now I need to turn the iPad off again, to place the screen.
How do I turn the iPad off without a touch screen and home button?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Lift up the connection from the battery.
To do this you will need to lift up the logic board until it stops touching the battery connector with the battery.
The logic board is pretty much stuck down by adhesive so you can keep lifting up the logic board near battery connector with your fingernails and loosen it.
Once it stops contacting with the battery, the iPad will be off, put something like a guitar pick to stop it from connecting again.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
Thanks, are there no risks for shocks or something?
из
No risk. Metal prying tools are not being used to do this.
из
Добавьте свой ответ
Michel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 54
