Pi-top is a modular laptop you build yourself. It’s a tool to help you start learning how to code, create devices, and expand your knowledge.
4вопросов Показать все
Where to get a Replacement Screen for the Pi-top v2
Where should I get a new screen for the Pi-Top?
Это хороший вопрос?
Оценка 2
1 Комментарий
I also have a Pi-Top V2, an became very frustrated when the screen blacked out intermittently.
I found that the screen bezel could be snapped off with no damage. It not easy, but not that hard. I used a big, sharp knife in the tight gap around the outer edge to carefully pry the bezel up, all the way around.
When it was off, I pushed the spot at the bottom of the screen where the flexible cable connects. Screen has worked reliably since then !
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hello,
Try sending a mail to Pi-Top support. They gave me replacement parts for free.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Joseph Wallack будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 730
