The Brother MFC-490CW is a all-in-one color inkjet printer released in July 2009.
Brother MFC-7860DW not turning on
My printer after being unplugged then plugged back will not turn on, I’m wondering if a fuse is busted, I need help to open it and check it or how to troubleshoot
Это хороший вопрос?
Счет 2
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @otepd ,
Try this solution I've provided for a Brother MFC -J4510DW and see if it works on your printer also.
My Brother Printer EMFC-J4510DW won't turn on
According to the comments in the Chosen Solution it has worked on a lot of different Brother printers, both laser and inkjet models
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Works for MFC-J5720dw printer - resets to factory default though
из
I found that these brother printers are very fussy about where they are plugged in.
First - Un plug it and wait 60seconds
Second - Plug it its own wall outlet, not a extension strip
Hit the power button, it should start up.
- James
Счет 0
Добавьте свой ответ
Tep D буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 17
За всё время: 10,792
