Выпущен в июне 2017 года как преемник Surface Pro 4. Также известен как Microsoft Surface Pro 12.3». Номер модели: FJT-00001.
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
Это хороший вопрос?
Счет 1
2 Комментариев
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Замена экрана Microsoft Surface Pro 5 guide.
Just a thought.
из
Go for an iopener, otherwise it's too easy to damage the surface.
из
Добавить комментарий
2 Ответов
Выбранное решение
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). Изображение
Товар
Heat Gun
$29.99
Был ли этот ответ полезен?
Счет 3
I would use the iOpener or a heatmat.
Счет 2
Добавьте свой ответ
Daniel Mossman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 1,690
