Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
iPhone 3GS 16gb problem when drop on the ground
my iphone problem is :
1st
-"restore needed can't make & receive calls restore via itunes".
-"wifi is in grey color"
-"iphone not sync & charge via usb"
-"not detect sim"keep searching network
-charging with ac adapter..when pull out the charger..iphone off
2nd
so i do the "erase all content & setting" in iphone setting.
3rd
now my iphone just stuck at apple logo during reboot.
Это хороший вопрос?
Оценка -1
2 Комментариев
I deleted your other "answer". This is the phone you dropped???
из
yup...and it has 1st problem above after it drop on the ground
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Try connect your phone to computer and enter DFU mode.
To enter DFU mode:
With the phone both connected and turned off, hold your power button for 1 to 3 seconds. Then press and hold the home button without realeasing the power button and count 10 seconds.
Then, release the power button and still holding home button and count 15 seconds.
If you already did that and doesn't work, I would say that some board may be broken. Maybe your dock connector board...
Был ли этот ответ полезен?
Оценка 1
5 Комментариев:
i hv done it...and it work in DFU mode..but now i don't know what to do next step..
из
Now open itunes and select restore. It will then install latest available ios.
из
"your iphone "iphone" cannot be restore.error 1601" this message show.
из
At the apple support page thay only say that you must update your itunes/quicktime to fix the error 1601.
Look for the error on google and ou find some guys that found themselves stucked on this error due bad jailbreak or something and they got out of the problem doing another jailbreak with another hack program.
But as long as your case is about hardware damage, I think it's not a software issue.
из
i'hv send it to technician to check for it...thank's for the answer.. :)
из
try uninstalling itunes and then re installing the latest up to date version.
It may be easier to visit a friend and use their version of itunes.
It may be that when you dropped the phone you have damaged the dock connector and this is why you are having the other problems also.
http://www.iphone4jailbreak.org/forum/ip...
http://ijafri.com/2011/02/21/fix-itunes-...
Оценка 1
1 Комментарий:
из
Добавьте свой ответ
ken будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,873
