Why no rear speaker audio
we purchased a 2009 Jeep Grand Cherokee and when we fade equalizer to rear, there is no audio on rear speakers - help!
Это хороший вопрос?
Это хороший вопрос?
Are you on Bluetooth? If so check to make sure that the rear speakers are enabled in the Bluetooth settings. Kenwood head units are known for this issue so if you have a Kenwood definitely check this out. If you go into settings, then to detailed settings you will see an option for something like Bluetooth HF audio. Go in there and you should see that only the front speakers are enabled. This is the default on their head units for the people who just use Bluetooth to talk on the phone and not stream their music. If it isn't kenwood it may have a similar setting. Also you could try checking the "advanced" or "pro" setup options to make sure the speakers are enabled there too. Hopefully this helps!
Был ли этот ответ полезен?
Wonderful thank u
Thank you Agent Neos followed your instructiin.
Kenwood DPX-U5130BT
Long press on audio settings > find HF> select All> confirm
Thank you for this - Unfortunately, I don't get this option on my unit, a KIV-700 with a KCA-BT300 module. No HF setting and so still nothing from the rear speakers or the sub. The unit is a 2010 unit - currently looking for a more modern version of this. The KIV worked fine until I upgraded my iPhone and then tried to use it with a USB-C adapter which does not support analogue audio, so have been trying everything to get it working with the new phone.
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 48
За всё время: 2,607
