Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
Simpler battery replacement process?
Could the process shown at iPod Nano 1st Generation Battery Replacement be simplified at step 7 by simply cutting and stripping the wires and soldering new battery wires together and covering with heat shrink tubing? This would remove the requirement to disassemble the logic board, thumbwheel and front face of the iPod nano.
Это хороший вопрос?
Счет -1
Добавить комментарий
2 Ответов
Выбранное решение
That's a little too ghetto for iFixit.
The whole point of that guide is to remove the logic board so you're not messing with any of the other components while using the soldering iron. iFixit presented the safest option. I wouldn't recommend that people follow your advise (even though it sounds feasible) just because it's kinda of jerry-rigged.
If you want to take a step further, you could technically just follow the soldering steps without removing the board. I do NOT recommend that. There's no reason to use heat shrink tubing at all.
Был ли этот ответ полезен?
Счет 0
dont know if its the battery how do I identify the problem
Счет 0
1 Комментарий:
matthew, it would work great for you if you post your own question. Click on the link on the right side of the screen "Ask a question" and give as much detail as possible. Like what device, what problem. has it just happened, anything you were doing just prior to? Need more info than the one sentence you posted as an answer to someone elses question ;-)
из
Добавьте свой ответ
fredvandenhout буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 1,004
