bent phone will battery charger work?
IPhone 6plus bent will the battery charger pack work phone will not charge
Это хороший вопрос?
Это хороший вопрос?
Yes. It’s unlikely the bend is only where the charger port assembly is I’d check for any rips in the cables but should be good.
Был ли этот ответ полезен?
Don't use any bent batteries ever as they can easily damage your phone.
I've had some cases where it damaged the software on the phone causing it to boot into DFU mode and I had to replace the battery and restore the phone at the same time.
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 42
3 Комментариев
Depends, how bent is it?
из Timothy McEvoy
Battery charger machine
из Battery charging machine
I am at a complete loss to understand what your answer is talking about. Care to elaborate?
из Jerry Wheeler
