Руководства по ремонту и поддержка смартфона Huawei P9 Lite, выпущенного в апреле 2016 года.
Huawei P9 lite battery issue
Hello,
I have there Huawei P9 lite. It has been damaged by milk. In Professional store it has been cleaning all the liquid. Motherboard, Touch screen, battery, everything has been tested and works. But there's a little thing that make connection between battery and other stuff that is broken. They tell me it's very cheap but they don't sell this piece anywhere. So if anyone has an idea about what i can do.
Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
The problem is that milk is corrosive so it may have damaged the plating on the flex cable connectors. If the flex cables are damaged they can easily be replaced (once you get the case open and can get to them), but if the connectors that the flex cables connect to are damaged then that is a much more expensive fix as these connectors are not replaceable (or sold anywhere that I know of - I suspect that they are either made in-house by the people that manufactured the PCBs or they are made for them & not available on the secondary market). If it is the connectors then you will have to replace the boards that the connectors are mounted to and, depending on the number/type of boards (motherboard, fingerprint sensor, cameras, etc.), it may be cheaper to replace the phone.
Был ли этот ответ полезен?
Счет 0
My battery is draining fast
Счет 0
Добавьте свой ответ
Youssef Ben Krid буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 358
