The Sceptre Model X9 Komodo VII monitor was released in 2005.
My T.V. keeps saying no signal!
I've tried unplugging and waiting several minutes on everything and I've tried every HDMI spots too and it keeps saying no signal please help?!
Это хороший вопрос?
Оценка 0
2 Комментариев
Thank you for responding but I figured it out!
из
What was it bc mine is doing the same thing
из
Добавить комментарий
Ответов (1)
Выбранное решение
sloppy19 sounds like a bad main board. You will have to at least take the back cover of your TV set and take a look at the board. Check for any obvious damage and lose wiring etc. Post some images of your boards with your question so that we can see what you see. Use this guide Adding images to an existing question for that. Also, verify your TV’s exact make and model
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
sloppy19 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,495
