Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1502вопросов Показать все
No text/SMS sound, only vibrate?
My iPhone 3Gs will play all tones EXCEPT the SMS/text tone...doesn't matter which I choose, all I get is the vibrate. I've restored my phone (not as a new iPhone), done a number of hard resets and power downs.
Any answwer?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Is your phone jailbroken? If it is you can SSH into it and remove any metadata files which may be corrupted, it's the only thing that I can think of that will cause a quirky issue like this.
Был ли этот ответ полезен?
Оценка 2
6 Комментариев:
+ good advice
из
Which corrupted files are you referring to? Yes, the phone is jailbroken, and also unlocked...
из
Give me a couple of minutes Michael....I'll SSH into mine and see the exact location. I'm Pretty sure it's under var/library/media/DCM apple but I'm not sure.
из
What Firmware are u running?
из
I have not been able to locate any .sqlite or metadata.plist files for the SMS App....Kind of odd being that many native Apple Apps have these files. I had a problem with the Photos App which I resolved by removing these files and re-launching the App. Which firmware are u on? I can remember a couple of years ago there was a problem in the firmware whuch caused this problem. I know how painful a restore as new is, so try this....re-download the firmware you are using but from a different source and restore your phone. If not...I think a restore as new is in order. U can always save all your other apps data on your mac or pc via SSH. Just dont save any SMS related data. U can always back up your phone and remove the sms.db file and see if that helps. That file is in var/user/library/sms. Also...try this easy one first: while in the SMS App hit and hold the home button for 5-7 seconds and force it to close or use SBSettings/Processes and close it there and re-open.
из
Показать 1 больше комментариев
Добавьте свой ответ
Michael будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 8,543
