Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
3530вопросов Показать все
Stuck at apple logo and battery gets warm
Hi I have a iphone5s that I replaced the battery and charging connecter on but when I put the new battery in it was stuck at a apple logo and I tried to put it into dfu mode but the home button is broken. And when I put in a dead battery it was flashing the HEY CHARGE ME! screen is it iOS curroption or a battery or is my logic board fried?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
In most cases, you can solve these problems by putting the phone into recovery mode and restoring it from backup. To do that, follow these instructions:
1. Connect the iPhone's USB cable to your computer, but not your iPhone.
2. Turn your iPhone off. If the phone won't turn off in the traditional manner, just keep holding the buttons until the screen goes dark.
3. Once you've turned the device off, press the home button on the face of the device and plug in the USB cable to the device's dock connector.
4. When it turns on, keep pressing the home button until the iTunes logo appears on the screen.
5. You'll know the phone is now in recovery mode because a window in iTunes will tell you.
6. You can then start the restore process by clicking the "Restore" button in the iTunes window.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
The iPhone still refuses to go into recovery mode so far nothing has helped
из
You can try an iOS recovery program like iOS System Recovery. With the help of this program, you can one click to fix your iPhone as well as iPad and iPod touch which stucking on Apple logo screen, DFU mode, white screen, blank screen and other system issues.
Three simple steps to fix iPhone stuck in Apple logo screen:
Step 1. Install and run the program, and choose the standard mode.
Step 2. Download and select firmware for your iPhone.
Step 3. Fix your iOS to return it to normal.
Оценка 0
Добавьте свой ответ
Ronan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 699
