Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
unknown IMEI and ICCID
Shows unknown IMEI and ICCID
Это хороший вопрос?
Оценка 14
2 Комментариев
please browse through the solutions to the right, this has been covered really well there.
из
also check out the solutions in iphone 3g
из
Добавить комментарий
6 Ответов
Выбранное решение
Most of the time that error is because the battery is not giving juice to the boot loader chip, try first to change the battery since the boot loader only will work from the battery power even so if the phone is directly connected to the outlet.
Был ли этот ответ полезен?
Оценка 9
2 Комментариев:
+have seen bad battery give these signs many times.
из
Imei:013268003346713 iccid: unknown
из
Этот ответ изначально был на другой вопрос.
This is a very bad warning. The problem could be many things, water damage, hardware failure. But lets go with something you can try. A DFU mode restore. Open iTunes on computer. Connect iPhone to computer. First push Home button and then push Power button, count 8 seconds and let go of Power button, keep holding Home button until iTunes says it has detected iPhone in Recovery Mode, then let go of Home button (usually about 15-25 sec). The iPhone screen should be blank (black), if an image is on screen you are not in DFU mode. If in DFU mode then click to let iTunes restore your iPhone. If not in DFU mode, try to enter DFU mode again. Even experienced users can have a bit of trouble entering DFU mode, keep at it until you get it into DFU, iTunes will tell you when (Recovery Mode window), as long as screen is blank (black). Good luck. Brad
Оценка 5
1 Комментарий:
Most times this will end in error 23... Cannot restore. The problem ic requires soldering skills and tools only professional repairers have. Let us know what you get with dfu and how you want to proceed
из
chang the battery and see if ur battery is deamag it will work.
Update
i agree with u. but some cease is different battery is good imei iccd is unknown.any solution ?
Оценка 5
iphone imei unknown iccid unknown
Оценка 5
3 Комментариев:
из
8997103113101650188
из
iPhone iemi unknown iccid unknown
из
I used to have the same problem no imei no iccid, after i change battery everything start working.
Оценка 0
it is the battery. I just fixed mine.
Оценка 0
Добавьте свой ответ
advinsp будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 14
За всё время: 37,800
