battery does not charge
when turned on get message that battery is low. Battery indicator indicates charge is low. Have tried to charge via 2 different usb port connectors and 2 wall adapters but do not get the battery icon to show it is charging and after trying both methods to charge stll does not show it has charged.
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Выбранное решение
Have you tried charging it overnight? Sometimes batteries are severely depleted. But if the battery still gets no power to it, my recommendation is to replace it.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
also clean your dock connector and make sure that you have a good USB cable. Check the dock connector for debris corrosion and bent pins.
из
Добавьте свой ответ
manuelo249 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 901
