1999 toyota camry speedometer and mileage not working
my 1999 toyota camry speedometer and mileage not working, and my car movement is bad .
Mise à jour (12/07/24)
Please help. I have 1997 Gx100 Toyota mark 2. Whenever the weather is hot, the speedometer goes off and the pedal areas gets too warm or hot for both the driver and passenger areas. The over drive sign appears on the dash board, gears starts to misbehave taking too long to change with a loud sound of the engine. Also the changing of gears is accompanied by a sharp rise of the rave count which quickly falls down once the gear has changed.
Это хороший вопрос?
3 Комментариев
I noticed my speedometer stops working when the weather is hot. When it goes off, the gear change becomes difficult. This continued for some months, but it has completely stopped working now. Although, I observed that it came on last week when I used the air conditioner.
What is the likely fault and how do I fix it?
из Suleiman Shaibu
@suleimanshaibu check the answer and work through the description. This could be your instrument cluster or the speed sensor.
из oldturkey03
I’m having this problem with mine and the car won’t shift or go above 10 mph. Is it not the cluster causing the obo and the speedometer to not work? Also. It only does this on really hot days. Please help
из Kristin Alisha
