Launched on November 2014, the HP Stream 13 is a thin unibody Windows® laptop priced to compete with Chromebooks and the entry level MacBook Air.
12вопросов Показать все
Help ASAP! Hard Drive Upgrade Via WifiPort!
Question and I need help!
I have an HP Stream and the hard drive is only 32gb and soldered via EMMC and need to upgrade it! I have the HP Stream 14 series this year I believe!
Now, I saw an existing forum regarding this laptop here: HP Stream 13 Disassembly for Upgrading the PCIe mini SSD
However, I do not get answers and I believe the user that said using MSata hard drives will work won't answer anymore! I am wondering if this has been confirmed working and if anyone has tried it and was successful! I have the wifi card here I took out: https://ibb.co/hANX98 and not sure what ssd to buy that will fit the existing port to try out!
Any assistance would greatly be appreciated!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Your WiFi board uses a PCI Express Mini Card interface. So it’s conceivable a a short mSATA board would physically fit. The only risk is if the system would recognize it.
mSATA SSD (mSATA solid-state drive)
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Daniel Ringuette будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 379
