Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
148вопросов Показать все
My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
Это хороший вопрос?
Оценка 4
2 Комментариев
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
из
Grateful it worked
из
Добавить комментарий
4 Ответов
Выбранное решение
Smack the bottom of your phone or lightly hit it on a table, it should come right out when you shake it!
Был ли этот ответ полезен?
Оценка 9
6 Комментариев:
This worked for me, thanks.
из
purrrrfect solution , thank you
из
Worked for me too thanks!!
из
This worked thanks alot. ?
из
Worked great for me. Thanks!
из
Показать 1 больше комментариев
Tweezers? Here is a video of someone getting one out:
https://www.youtube.com/watch?v=zA5xYT-x...
Оценка 1
1 Комментарий:
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
из
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
Оценка 1
2 Комментариев:
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
из
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
из
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
Оценка 1
Добавьте свой ответ
Robin Kamps будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 29
За последние 30 дней: 177
За всё время: 21,824
