Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Вопросов 20 Показать все
Logicboard compatibility of ipad 5 and ipad A1475
I am looking for a logic board for my ipad air A1475. I see some suppliers offering logic boards for ipad 5 wifi. Can I use an ipad5 wifi logic board in my damaged ipad A1475 ? Thanks.
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Выбранное решение
Yes, they are the same iPad called by different names. You just have to make sure the one you're buying is for A1475, since other iPad Air boards might be wifi only, without the 4g cellular part.
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Thanks for the helpful comment. I have managed to get an unlocked logic board for a1475 wifi+4g cellular with 64 Gb memory. I hope, this would be ok for the faulty board (which had 32 Gb memory).
из
@dmahapatra It will be ok, you'll only have a bigger storage available, no other differences between the two boards in size or other smaller parts. You can get help from the following guide in your replacement:
iPad Air LTE Logic Board Replacement
Enjoy :)
из
Thank you so much.
из
Добавьте свой ответ
Durga Mahapatra будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 859
