Trackpad cursor moving around on its own and clicking anywhere
Hello.
I own a Macbook Pro Late 2011 model and recently the trackpads cursor is behaving weirdly, like it moves around on its own, it clicks anywhere.
I am guessing I need to change my trackpad ?
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Will the trackpad on above link help me ? Do I need to check model number A1278 ?
or just 'Mid-2009--Mid-2012' is good enough to assume it will work with my laptop.
Thank you
Update (07/16/2018)
even the vertical page scrolling sometimes does not work
Это хороший вопрос?
2 Комментариев
the cursor erratic behavior seems to have stopped today but the 2 finger scrolling is not smooth, sometimes I can not scroll.
and then it works smoothly.
Using the coconutbattery app I found out that MBP battery had 1643 cycle count.
из jiten shah
Sounds like you have two problems here! A battery which also needs to be replaced. As you can see here you've exceeded its lifespan! Determine battery cycle count for Mac notebooks
из Dan
