Haswell business laptop introduced by Dell in 2013. This system is notable for being the first Haswell business laptop released, but has multiple known problems - including AMD GPU failure. A new battery will operate the laptop for ~4-7 hours, depending which one is installed.
10вопросов Показать все
replacement keyboard not working
Hi there,
I have recently replaced my keyboard with a non-original keyboard and it works only a few minutes and stops. After every BIOS update it works again and stops after a few minutes.
Any idea how i can get this non-original keyboard to work?
Regards,
Siviwe
Это хороший вопрос?
Оценка 0
1 Комментарий
You tried to use your keyboard in safe mode if it is working then there must be an app causing error
из
Добавить комментарий
1 ответ
Выбранное решение
Need to try a DriverPack Solution Software and update the keyboard driver. If the problem persist your new keyboard might have a defect.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Siviwe Xegwana будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 194
