Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
31вопросов Показать все
Red Screen/ attempts to boot twice then red screens
Had a iPad mini 3 come back for a loose home button re-adjusted and adhered the button back. Went to test the device attempts to boot x2 then red screens
What I have tried
- unplugging anything and everything that's not soldered down minus the LCD
- cameras front and rear
- power button
- digi
- home button
- aux
- antennas
- coaxel cables
What I have not tried
- restoring
Anything would be helpful thank you for your time ahead of time
Это хороший вопрос?
Оценка 0
1 Комментарий
Update1:
- tried new battery x2
- took out sim card
- tested for boot without LCD
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Have you checked charger port if it's loose? Sometimes you may need to tighten the screws up for the charger port.
Red screen can also mean the tristar (U2 charging) chip being bad or NAND chip failure.
Might need to do a restore but that will wipe data so if data is needed leave restore for last resort.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Mitch Kelly будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 64
