7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
FPC connector socket replacement
Is the FPC connector socket interchangeable with a different model?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Which FPC connector are you referring to?
I’ll assume you are referring to the digitizer FPC as that is the one that fails the most. Apple does a great job in using different connectors almost all of the time ;>). They use different types and genders on virtually every generation of device, with only a few exceptions. The mini digitizer FPC is used on the mini, mini 2 and mini 3 but no other FPC used through out their product lineup is the same. You can find it here.
Replace the digitizer cable connector on the logic board of an iPad mini. This part requires microsoldering. Изображение
Товар
iPad mini Digitizer FPC Connector J1700
$2.99
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
dreaminbeech буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 77
