Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
1199вопросов Показать все
There’s a black “ink”spot in the bottom right corner of my screen?
My screen has no cracks on it, I’ve dropped it twice.
The first time it landed backside down and I noticed that a small black spot that sort of resembles ink appeared. I dropped it again today, it landed the same way, and the spot got bigger.
I can still control my screen directly on where the black spot is im just not sure what it is or how it could be repaired
Это хороший вопрос?
Оценка 9
Добавить комментарий
4 Ответов
Выбранное решение
If you could post a picture, we could say for certain but it sounds to me like the actual OLED has been damaged. If that’s the case, then you will need to replace the screen.
If you want a high quality screen replacement, then Apple is still your best bet. However if your housing is damaged, they may refuse to replace the screen, in which case an independent repair shop will be able to replace the screen. Just ask about the quality level of the replacement screen because there are some inexpensive (relatively speaking) aftermarket LCD’s and now aftermarket and premium level OLED.
Был ли этот ответ полезен?
Оценка 9
9 Комментариев:
Hey does it spread all over after you dropped off ??
из
It's not spread ed it's just down at the last of the month
из
I just wanted to know what the plus was for at the end of the calendar
из
Nothing appears to be damaged it's just got a plus sign at the end of the calendar.
из
I don't believe anything is damaged if it is then the glass and back are a waste of mone
из
Показать 4 больше комментариев
Black splotches inside LCD display are caused by dropping the phone.
To get that fixed you would need to get the hole display replaced. Most expensive phone to get it replaced.
[связанный продукт отсутствует или отключен: IF377-003]
Оценка 6
4 Комментариев:
Does the warranty cover this type of damage?
из
Does it grow with time on iphoneX?
из
It can get worse over time as it bleeds like ink in a display that expands. This would not be covered under normal warranty as it is considered physical damage.
из
Is there a way to arrest it?
из
So I cracked my phone at the bottom right corner of my screen and it is showing vertical lines on that side of the phone can I get it fixed?
Оценка 0
1 Комментарий:
You'll need to replace the display.
из
I think this will be helpful for you
https://okadtech.com/how-to-fix-black-sp...
You can try the solution to solve this problem.
I was facing this issue in my iphone x tried this article solution it didn’t work.
Tried the same solution in a others phone it worked.
Conclusion - If the pixel is dead then you can’t repair it but if it’s stucked then it can repaired.
I dropped my iphone x so maybe the pixels are broken so i unable to solve this problem. I have to replace my screen.
It all differ.
Оценка 0
Добавьте свой ответ
Xandria будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 52
За последние 7 дней: 188
За последние 30 дней: 700
За всё время: 207,249
