Asus Q534U power button mashed into case body; needs replacing
Hello! I have an Asus Q534U laptop, and it took a tumble from about 30” in the air, off a rolling suitcase, while in its laptop bag (padded on 3 sides, but not the top … ugh!). Bag tumbled top over bottom, hit the floor with an audible thump, I started praying. Turns out the unpadded top of the bag, where there also is a small niknak pocket, must have had some small item in between the laptop and the floor. The laptop hit this random object directly across the power button, mashing in the silver button cover and slightly denting the case directly over side button.
I’ve “dug out” the button cover, and kinda unbent the case about the area (wasn't too bad), but the power button is entirely unresponsive. I think it needs changing.
Is this something you can help me identify the part for? Any thoughts if this is something I can manage to access fairly easily? I can manage the tools and any basic soldering, but I'm really hoping its simple plug and play component.
Appreciate the help!!! Repair shop/Geek Sq seemed entirely unreliable and looking to rip me off. With your help, maybe I can save myself.
Update (09/18/2018)
Это хороший вопрос?
3 Комментариев
Could you post some pictures of the damaged area and the button, so we get an idea of the situation.
из Luis Anniel
the scratches seen in the last photo were made by me, leveraging the button out of the case where it had been jammed in and upwards. the scratches on the case are also me. the initial damage was rather innocent looking, till I noticed the power button missing (found inside the upper lip of the case hole). thank you again for asking to take a look
из RichardsST
thank you!!!!!!!!!!!!!
из RichardsST
