Replaced Battery no longer booting up stuck on Apple logo
I just replaced my iPhone 3GS' battery yesterday and as soon as i put it back together nothing happened. black screen, I rechecked all the conections in the device and im sure everything is fine, when installing i did accidentally break off the grounding contact located near the "do not remove" sticker, could this be why its not working. Also if i charge the phone through my computer, but if i charge my phone through the wall charger it eventually turned on, but would only display the apple logo, no spinning wheel or anything . Im going through right now attempting to put the old battery back in to see if that fixes anything
update
just put the old battery back in the phone and now it will turn on without being plugged in to the wall, but is still stuck on the Apple logo
update
its now being reconised in itunes, so possibly just a battery compatibility issue.
the apn for the battery was 616-0435
Это хороший вопрос?
3 Комментариев
So after i put in the new battery it turned on and reconised itself in itunes, now i did a restore in hopes that i would make it go past the apple logo and now after it finished and unplugged it and now i get the logo with the spinning wheel. it has been sitting like this for about 20 min
из Shane Van de Sype
has the new battery charged on the wall charger? you may not have enough charge to boot up.there are lots of problems with these replacement batteries and stuck on apple. even though people have written lists of compatible batteries they continue to be a few that cause this incompatibility problem with the ios. check the number matches the old, try a dfu restore. return the new battery..
из pollytintop
I just changed my battery yesterday with one purchased from ifxit and also have the same problem if you come up with a solution please post it. I will do the same if i figure it out..
thank you
из ladyjcaptain
