Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Extremely bad sound when recording videos
I cant find the reason why my microphone wont work when I record videos with the rear camera?? I have now changed all three microphones on the phone but there is no change in the sound quility when recording videos? Ive also tried to reset the phone completely…
Is there some more component that affect the sound when recording? If I screem in front of the mic I can hear it when I play it but theres mostly background noice…
Theres nothing in the way for the microphone. Please I need help!?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Have you checked the filters for the microphones / speakers? These can get clogged up and require a tiny bit of water and a brush to clean them if they are blocked.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Yes checked them, no problem there.
из
What type of bad sound is it? Is it a clicking sound, a static sound? I have found that if it is a clicking sound, it is often due to the brace between the microphone and the housing on the bottom of the phone not being seated properly
Оценка 0
3 Комментариев:
Thank you for your answer. Its a static effervescent noise.
из
This maybe related to the audio IC on the motherboard. try re-soldering that IC.
из
I think you’re right, there’s something wrong on the logicboard. Tried with another logicboard and voilà, everything works fine! Had saved many hours and grey hair if I tried this earlier...
Unfortunately I dont do soldering, so I think that logicboard is doomed.
из
Добавьте свой ответ
David будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,347
