This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
83вопросов Показать все
While im on youtube or netflix...
the video or movie keeps freezing (pausing) on its own or will pick out the next video on its own. what could be causing this and how do I make it stop? it has been dropped on the floor for the 2 foot tall coffee table.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Prior to dropping the game pad was it doing this behavior you mentioned? If not, something might be broken inside the game pad which would probably be the Digitizer.
Update (09/27/2018)
@justlost Here is a replacement LCD and Digitizer screen assembly and a guide on how to replace the LCD and Digitizer. If it turns out that replacing the LCD and Digitizer display assembly does not solve the problem then you can return the LCD and Digitizer display assembly and get your full money back.
Wii U GamePad Screen
Wii U GamePad LCD Display Replacement
Wii U GamePad Screen Изображение
Продукт
$24.99
Был ли этот ответ полезен?
Оценка 2
5 Комментариев:
ok how do I fix that?
из
@justlost You did not answer my question. Was this happening before you dropped your game pad?
из
No it wasnt @ajcooke01
из
Thanks @ajcooke01 i appreciate that
из
@justlost No problem! If this solution worked out for you, go ahead and mark it as correct so we can clean up answers and so that other people know what do do.
из
Добавьте свой ответ
steven_kurzinger будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 96
