Chromebook, выпущенный Lenovo в 2016 году для образовательных целей.
Why does my chromebook keep crashing
i will be doing work on my Chromebook and then bam it just crashes and restarts
Это хороший вопрос?
Счет 0
2 Комментариев
how often does it crash? is it while using any program? how much Ram does the system tell you it has?
из
it has 2 gigabytes of ram and I can have all the tabs and programs closed and i try to change wallpaper and it crashes.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
This is a very common problem with all types of Chromebooks. A powerwash is typically needed in order to fix this issue, although. Back up any data you have stored on your Chromebook as powerwashing your Chromebook will erase all of it’s data!
When you are ready, head over to your status area to access the Settings From here, choose Advanced Settings, and look for the section called Powerwash. Here, choose Reset, then choose Restart and enter your Google Account information.
  • Note that you should only do this with a personal Chromebook, not a work or school version.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Lar5 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 34
За всё время: 677
