No power on Sony model DVP-SR510H DVD player
Push the power button, no power ‘on’ light. Made sure it was properly plugged into the surge protector strip, check. Make sure the strip was plugged into an outlet and the power is on, check. Unplug it from the power strip and connect it to another wall outlet in the kitchen that has power. Push the power button, still no power light. Is it because these are not expensive that they die so easily? Can I fix it?
Это хороший вопрос?
Hi,
Unfortunately as there is no service manual or teardown guide available online (or at least none that I could find), I can only suggest that you open the unit and check if there is any obvious damage to any components (e.g. burnt, stressed etc) or perhaps even if there is a blown fuse in the power supply section of the player etc. (if there is a fuse and it is blown be aware that there is always a reason that a fuse blows).
Be safety aware and ensure that the power is totally disconnected from the device before you attempt to open it.
If you are uncertain as to whether a component looks faulty, take some close up pictures and post back here and hopefully someone can help you further.
Here's how to do this Adding images to an existing question
из jayeff
my dvd player door want open
an the buttoer want work dvd light is on
из larry williams
Hi @larrywilliams68435,
What is the model number of your dvd player?
из jayeff
