Released 2014, full name is recognized as Cuisinart PerfecTemp 14-Cup Programmable Coffeemaker. Black model shown, also applicable to white.
18вопросов Показать все
Water is pouring out of the bottom of the machine
The machine has worked fine for several months. Without moving it or making any changes, water now pours out from beneath the machine from the open holes on the rear bottom of the unit
Это хороший вопрос?
Оценка 2
1 Комментарий
I’ve had this happen with two of my Cuisinart PerfecTemp 14-cup programmable coffeemakers. The second one was under warranty and the replacement displayed an error code of ErH after one use. I was told by customer service to unplug the unit and wait 24 hours then plug back in. It still gave the same error message.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @kyotesue ,
Here’s a link to the ifixit Cuisinart DCC-3200 Hot Plate Replacement guide.
Check if the red tube shown in Step.3 (both ends of the silver metal pipe) has become loose or split etc.
Был ли этот ответ полезен?
Оценка 1
Cuisinart DCC-1200 Hose Replacement
Оценка 1
Добавьте свой ответ
Sue Malone будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 1,251
