Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
64вопросов Показать все
How to change memory card slot
Is there guide that explain how to change broken memory card slot?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Nikon D3200 Motherboard Replacement
this will gain you access to the part you need to get to. Then you will need to be able to remove the cover for the memory slot (desolder the legs), then desolder all the pins of the reader, remove reader, solder new one in, replace cover. reassemble camera.
it may be that you don’t need to do all of that, if it is a bent pin you can use a small metal probe to gently realign.
Был ли этот ответ полезен?
Оценка 4
It lacks lots of steps like removing the screw behind the dial for the eye-visor, before opening, there's also a screw behind the thumb grip to remove before opening. There's also 4 little cables on the top left on the motherboard to unsold and also one screw om the left, so we can remove the motherboard and detach the connector of the LCD. Open carefully by the top of the mother board and detach the LCD connector by lifting gently the little black bar at the back (it's not the same connector as on the other side, if you pull the white bar it breaks)
ha! and forget changing just the SD card slot. It's 20$ for a good one, and it's just hard to replace for anyone not used to do it… buy a new motherboard it's quite cheap on eBay for an original one, changing just the SD is just too risky for a beginner.
Оценка 0
Добавьте свой ответ
christian.cascone будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 2,310
