4-дюймовый iPhone выпущенный в марте 2016 года на той же самой платформе, что и 6s. Доступен в серебристом, сером, золотом и розовом цветах с 16/64 Гб памяти. Модели A1662 и A1723.
1049вопросов Показать все
Name of this component for iPhone SE?
Hello, which is the name of this component for iPhone SE? First time with my broke iPhone when I tried to replace motherboard, this component has been removed from iPhone. Which is the function of this component? And is possible repair it with a something as the welder? Because I noticed it is attached to iPhone.
Image of component:
Thank you in advance for reply.
Это хороший вопрос?
Оценка 0
1 Комментарий
Добавить комментарий
2 Ответов
Выбранное решение
That’s a teared off part of the wifi/bluetooth antenna. It’s a pretty inexpensive part but you’ll have to buy a new one. No need for soldering, it’s simply glued to the housing.
Был ли этот ответ полезен?
Оценка 4
2 Комментариев:
@refectio That's where it was hidden, thanks for the addition =:)
из
That’s part of the rear case. You can see it in this photo from the teardown, and this one too.
To get WiFi/cellular connection, you’ll need to buy a new rear case, since the connector is permanently attached to it, and can only come off if the cable is torn. It looks like you can relatively easily get new (though not necessarily OEM) cases on eBay.
Оценка 0
2 Комментариев:
No, there's no need to replace the housing, it's sufficient to buy the new antenna and replace the part of the old one left, some warming makes the job easier.
из
Oh, I had no idea that it wasn't part of the rear case!
That's nice to know. Thanks for clearing that up!
из
Добавьте свой ответ
Patrizio Masini будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 81
