Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624вопросов Показать все
no LCD or backlight. tested two LCD panels, external monitor is good
i recently decided to make another pass at this 2012 MacBook pro which has been sitting in my drawer for some time. I have no history on the unit, it arrived as part of a lot of non-functioning MacBooks. no tripped moisture indicators, and the innards didn’t appear tampered with.
said MacBook will chime and boot fine, but never outputs display to the internal LCD. it’s obvious that the backlight isn’t illuminating, and the flashlight test yields no activity on the LCD itself. needless to say, uncountable SMC and NVRAM resets have occurred, as well as reinstalls of macOS. i have tested this on two separate LCD panels, the second is “known good” from a working machine. for what it’s worth, this test was accomplished by transferring the MLB to another complete MacBook, rather than simply connecting another display in place.
i have my normal routine for no-backlight-having MacBooks, but the no LCD is throwing me for a loop.
advice (other than genius bar, replace logic board, etc) is most welcome!
i have tested all of these points, none show 3v3:
following the board view, i also have no 3.3v at R1984, but i don’t know how to follow the trace to what i’m assuming is the other side of the board?
there appears to be some tomfoolery at the battery status connector (which has an SMC function as well)
Это хороший вопрос?
Оценка 0
2 Комментариев
hmm, this does look like a logic board issue to me, sad to say. I’ll let the more experienced people do the talking though.
из
yes i have surmised that it's a logic board issue. my hope is a short list of common points to check!
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@reverendalc
check the display connector. Check for bend broken or corroded pins. Post some images of your logic board with your question. That way we can see what you see. Use this guide Adding images to an existing question for that.
Measure the connector and see if you have the voltages required to turn the internal display on.
Был ли этот ответ полезен?
Оценка 1
18 Комментариев:
always pleased to see your replies old turkey. i've attached a photo of the LVDS connector and cable end. they both look very healthy.
из
The cable checks out from an appearance standpoint. Still could be an issue with the cable or the connector on the Logic Board itself though.
из
additionally, i've tested every pp3v3_lcdvdd_sw at and after U9000 with no satisfaction
из
@reverendalc connector looks really good. Are you saying you do not have 3.3V on pp3v3_lcdvdd_sw?
из
that is correct. i also added to my original post all of the points i've tested for 3.3v. i'm currently looking at the S5 which feeds U9000, and both pins 2 and 3 carry 3.3v into U9000
из
Показать 13 больше комментариев
Добавьте свой ответ
Ronnoc Nailli будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 153
