Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Why does my ipad have this glitch thingy on the side
my ipad constantly is glitching on the side and i tried to restart my ipad but it wouldnt go away. the ipad still works perfectly and everything but its really annoying because i dont know what it is
Это хороший вопрос?
Оценка 0
2 Комментариев:
Take a photo of what it is and post it here. We can’t tell from that description.
из
misa what is your definition of a "glitch thingy"? What does or does it not do? What does it show on the screen? If you need to post some pictures to show us, use this guide Adding images to an existing question
из
Добавить комментарий
Ответов (1)
If you’re describing intermittent touch on one side of the screen, then it is likely due to a bad digitizer. You will need to get the glass digitizer replaced. An easy test is to touch and hold an icon until it shakes, then drag it all over the screen, starting on one side and dragging it the full length up and down from one side to the other. If the icon falls away from your finger, that is the section of the screen that is faulty. Very easy repair and around $100, depending on the model of iPad.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
misa будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 90
