1998 Buick Park Avenue engine coolant low light come on all the time?
Why does my 1998 Buick Park Avenue engine coolant low light come on all the time? I checked the antifreeze in the radiator and reservoir added some in both. the reading still pops up. What i do is push reset it turns off , but every time i restart the i need to push reset why?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Hi @arcangel ,
Don’t know if this link may be applicable to your particular model vehicle but worth looking at.
Scroll down to the section headed "Low Coolant" Indicator On, Coolant Level OK
Был ли этот ответ полезен?
Оценка 2
Наиболее полезный ответ
This could be indicating that a gasket is going bad, or the sensor is just no longer properly functioning. It is good practice to keep an eye on the coolant levels to ensure you aren’t actually losing the coolant you put in, and damaging your engine.
Оценка 2
Добавьте свой ответ
Juan Ruben Gutierrez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 481
