¿por que mi MacBook no arranca?
mi macbook se queda en el logo de apple
Why doesn't my MacBook start?
My MacBook stays at the Apple logo
Это хороший вопрос?
Это хороший вопрос?
Try starting up from your original system installation disk by inserting the disk and holding down the C key on start up. Then run Disk Utilities and see if you can repair your drive.
Back up your drive to an external source ASAP as it may be failing and need a replacement.
Intente iniciar desde el disco de instalación del sistema original insertando el disco y manteniendo presionada la tecla C al iniciar. A continuación, ejecute Utilidades de disco y vea si puede reparar su unidad.
Haga una copia de seguridad de su unidad a una fuente externa lo antes posible, ya que puede estar fallando y necesita un reemplazo.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 54
6 Комментариев
Si tu sistema solo muestra el logotipo de Apple, deberías ver una barra debajo que se alarga (de izquierda a derecha). ¿Ves la mitad del camino?
If your system only shows the Apple logo you should see a bar underneath it which gets longer (left to right) Do you see it getting half way?
из Dan
@danj There's no loading bar in the older versions of Mac Os that machine can run..remember the old spinning wheel ? ;)
из arbaman
If I remember correctly Mavericks was the last version with the spinning wheel.
Sometimes I ask questions to help define what the OS release is so don't always assume ;-}
из Dan
@danj Well, I can't say what Yosemite shows when loading, but Mavericks is still a spinning wheel Os for sure, and that's by far out of reach of any 2006 Macbook, so, no loading bar for sure :)
из arbaman
Well, thats not quite true, think about that how is that possible. I agree thats not something you should do, people do it.
из Dan
Показать 1 больше комментариев
