How to re-programmed the ZTE Axon?
May phone stopped working long ago i want to restart it
Это хороший вопрос?
Это хороший вопрос?
I believe you can hold the “volume up” button and “power” button simultaneously for five seconds. If done correctly, assuming the phone is charged, from there, you should be able to press volume up and down button to enter the boot menu. Try the “reboot” option to see if the phone is still operational so that you may recover pictures, contacts, etcetera, or continue using the phone. If this fails, go back to the boot menu and try the “update from cache” option. Then, if that fails, try the wipe/reset option. Good luck.
Был ли этот ответ полезен?
The problem with my device is that, after I did as you said in the answer above it used to show me that 'unfortunately the phone has stopped' and I press OK it showed me 'unfortunately the fingerprint has stopped'. what is the solution?
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За все время: 355
Cómo quitar el patrón
из Gustavo Ernesto Ibarra Mendoza
