Why is my RPM going from low to high, once my temperature is perfect?
My Volkswagen Jetta is a 2.5, 5L, it’s over heating it goes from low RPMs to high RPMs and I have everything in check I have done the oil change, changed the spark plugs, changed filters, and a mechanic told me to clean the carburetor with carburetor cleaner and I did put some put i think it was no enough. It’s still doing the same problem and it’s wasting way to much gasoline then the usual now I need some help on tying to find what is it? Help please
Это хороший вопрос?
2 Комментариев
@jessol16what exact year is your Jetta? when you say it is overheating, what have you checked on that. Everything you have doen thus far will not change any overheating problems. You checked your fan? Your coolant level? What did the old sparkplugs look like? Your Jetta most likely will not have a carburetor, what did you clean and how?
из oldturkey03
It’s a 2006 2.5 5Lwell it’s not really like overheating the temperature needle is on point where its supposed to be at. What it does is the RPM needle goes from 10 RPMs to 20 RPMs when the car is parked or on neutral. They were brunt from the tips some what wasted, the coolant it’s water, I put some carbur-clean is almost like w-40 I put some to clean the throttle body but it still does the same. @oldturkey03
из Jesus
