Will a repair kit for a Samsung S7 work on an S7 Active?
I need to replace that battery on my S7 Active, but I don’t see any kits for the active—just generic for the S7. Would that work? I’m specifically wonering whether the waterproof seal would fit—is it the same size?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
They are not compatible, kit can be found here: https://www.repairpartsplus.com/Samsung-...
As for the waterproof seal, you can't use the same as the S7. eBay is the only place I could find the precut adhesive strips here: https://www.ebay.com/itm/Samsung-Galaxy-...
Был ли этот ответ полезен?
Оценка 0
Thanks for the information. Ths seems like something that should have been easier to clarify. Maybe the folks at iFixit should consider adding a specific notice about incompatibility to the results of searches for S7 active parts.
Оценка 0
Добавьте свой ответ
r torrance andrews будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 144
