Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
284вопросов Показать все
Can MacBook 2016 or newer be iCloud locked PERMAMENTLY?
Hi there
I have possibility to buy MacBook Pro 15” 2017, seller says it is “iCloud” locked.
I had many MacBooks before but never newer than 2015 (pre Touch Bar).
I 100% sure I know it is IMPOSSIBLE to have it iCloud lock - as if I do format disk and reinstall system iCloud lock will be gone.
I know about FIRMWARE / BIOS in those 2015 and older - but seller says it is not that lock - it is iCloud lock like in iPhone.
Can someone please tell me what are possibilities to PERMAMENTLY lock of MacBook 2016 or newer?
Thank You
Это хороший вопрос?
Оценка 2
3 Комментариев
You just need to wipe the machine.
This can be done by a local computer shop rather easily if you don’t have the correct tools.
You’ll need a bootable USB operating system to re-install.
из
If this was a 2015 or older MacBook it could be defeated, the newer 2016 onward models not.
Here's a good write up on the older models: Apple's iCloud lock for Macs is not very secure
из
Добавить комментарий
2 Ответов
Выбранное решение
The older MacBook Pro’s firmware lock was defeat-able! But it was a chore to do. The newer 2016 onwards MacBook Pro’s are a different story, The 2018 T2 chip models even more so! They are just not able to be broken.
Here the storage is soldered into the system so you can’t remove it to reformat it externally, to add to it the EFI chip is now tied to the CPU’s ID. Apple has made a large effort to reduce theft just like they did with the iPhones & iPads.
Make sure you haven’t confused a firmware password How to set a firmware password on your Mac. Many people confuse the two.
There are a lot of fly by night sharks who will try to tell you they can break iCloud (iOS or MacOS) sorry to say it’s a rip off!
Был ли этот ответ полезен?
Оценка 2
If this MackBook has iCloud Lock, then only the original owner has the option to unlock your device. The only way to do is to go into Apple services and to ask. But just to have the contract bill documents about this device. If not have a proof that you are the original owner on this device, then not possible to remove the icloud activation lock.
Оценка 0
4 Комментариев:
My iMac 2013 has iCloud Lock - and Find my iMac On - but when I install new fresh macOS - everything is gone and new buyer - thief can use it like new.
из
If you don’t know the owner on this iMac, then you don’t have an option to unlock. Can be permanently locked.
из
this guy icheck Is an freakin idiot dude don't listen to this trash.. Dude if you pull that harddrive out and replace it all that information is gone, but on the newer ones the hard drive is soldered on to the board, I have the same exact question can you wipe them or not. This guy up here Is a ##&&% .
из
@Saed Wifki - Replacing a SSD chips won't unlock your Mac! Saed you really have no idea how iCould works and how the T2 chip makes things even harder!
Let me put it to you this way you have a raw egg in your hand you need to get the Yolk out but you can't break or alter the shell or make any holes. If you can figure that out you know how to break iCloud.
из
Добавьте свой ответ
Bart будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 82
За последние 30 дней: 449
За всё время: 28,089
