Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
iPhone 7 stuck in boot, still after dfu? works for an hour after
Hello, I had an iphone 7 at my store yesterday.. the phone showed apple logo then turns off and apple logo appears again. I put the phone in recovery and updated via itunes. it was complete and I got to the lock screen typed in password. then everything seemed to work as it should. Today they came back, phone was back in boot loop. I put it back in recovery mode and itunes resat the phone back to “new”.
Now about 2 hours later they called and its the same issue even tho I was playing on the phone for about 30 minutes before calling them saying everything was fine.
Anyone know or has an solution to what the issue could be?
I did try with a new battery as well, same issue.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
i have n issue right now that a 7p boot loops after a screen replacement but if i unplug front camera flex it boots normally and stays on, if i plug in cam flex with phone on it works for 2 mins then starts boot looping, not sure this is any relevance to your issue but try running with front cam unplugged and see what happpens
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
That is an different issue. all you need to do is to replace the facetime-flex its because the iphone 7 plus facetime flex is really sensitive being pulled of the old screen
I might test it tho. it was never a screen repair or anything has been repaired on the device. it only came to my store because of boot loop issues,.
из
Добавьте свой ответ
nicolay.94 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 47
