Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Lighting jack is not working
My iPad Air 2 is not charging. I’ve tried restarting the device, cleaning out the lighting port, changing cords, chargers, and wall outlets to no avail. I was looking for other ideas as tot he cause, or for a replacement part to replace the defective part.
Это хороший вопрос?
Счет 1
1 Комментарий:
Thank you all for the info. Much appreciated!
из
Добавить комментарий
2 Ответов
Unfortunately, your port may be defective. It is soldered to the Logic Board and would require micro-soldering to be replaced. If you want to repair it, it may be cheaper to take it to Apple, as micro-soldering can be very expensive.
Был ли этот ответ полезен?
Счет 0
You can buy a replacement charging dock voor the ipad air 2 it isnt that hard to repair no soldering needed , buy one with flex cable.
Счет 0
2 Комментариев:
The charging port flex assembly is connected via soldering to the logic board. So it will require soldering to replace that charging port.
Good video on how it's done here: https://www.youtube.com/watch?v=IdyIQYrO...
из
Alec and Ben , sorry you are right. For the normal ipad 2 it is easier and with a flex cable.
из
Добавьте свой ответ
Ryan Lantz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 29
За всё время: 428
