The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
My machine will not spin
My Kenmore will go through all the cycles except spin. I can move the tub a little and it will spin after that. Any ideas on what can cause that.
Это хороший вопрос?
Счет 0
1 Комментарий
what is your exact model number?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
bettye747 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 98
